What gear ratio is this
Old Sep 17, 2007 | 12:57 PM
JUICED96Z's Avatar
Default What gear ratio is this
Car has a TH-400, 28" tall tire, at 60mph it is at about 2700 RPM.
I know there are calculators for it but I can't find the good one.
FIRST GEAR SECOND GEAR THIRD GEAR
2.48:1 1.48:1 1:1
Old Sep 17, 2007 | 01:11 PM
8a8mfh's Avatar
3.42 gears come out to 2601 rpm.
This is assuming your vehicle mph is correct, you can't go off the speedo if your set up is not calibrated for the rear gear.
Old Sep 18, 2007 | 12:09 PM
JUICED96Z's Avatar
Forgot about that and tire size.
Ill just pull the cover off this winter. Stall could be effecting it also.
Old Sep 19, 2007 | 10:46 AM
jfman's Avatar
just put the car on jack stand and rotate the wheel 360 degrees. Count how many times the driveshafts spins. If it spins 4.1 times = 4:10 gears get it ?
Old Sep 19, 2007 | 05:37 PM
JUICED96Z's Avatar
Yeah Ill try that.
Old Oct 17, 2007 | 01:40 PM
JUICED96Z's Avatar
Looks like its going to be a 3.73 guys.
Also looks like first and second have been re-geared.
Shifting at 7k I am doing like 70mph going into second..........
