I need some help
1. How much damage can be done with this as a problem? (i.e. is my torsen and other internal parts toast?)
2. Is it as easy as changing the pinion bearing and the fluid again?
I have a spare rear that I bought to put in the car I just got rid of and it only has 14k miles on it. The only problem is the 01 SS is a 3 channel rear and the spare rear that I have is a 4 channel rear.
3. Is there anything I can use this spare for to replace the bad parts of my current one with or will it be too big of a hassle?
I'm a newbie to rear diffs. I know how to swap complete axles, but haven't had to deal with internal problems with them yet. What would you guys do if you were in my situation?
Thanks in advance for the help/advice. Right now, I'm having to drive this car to work because my wife's car is in the shop and I don't want to have to drive the Chevelle because my commute it close to 70 miles a day.
Well, against my better judgement I drove the Camaro this morning, and what do you know halfway to work this morning the noise goes away and you can barely hear it. I did take it to a mechanic at lunch and we drove it and the noise is barely noticeable now. Hell, my 99's rear was louder than this one is now. I felt kinda stupid telling the mechanic that the noise was 10 times louder than it is now. We did put it up on the rack and about the only thing we could find that could cause the noise is the rear ujoint seems a little loose. I told him to go ahead and fix that and I'll see how it does today and in the morning.
I'm almost thinking that the fluid that was changed yesterday was probably the original or close to it. It's weird though that after changing it yesterday it was still noisy and then halfway to work this morning the noise started getting less and less.
