Moser Wheel Stud ???
Old Sep 22, 2007 | 08:27 PM
SS1875's Avatar
Default Moser Wheel Stud ???
Anybody know whether or not the Moser 8000 (1/2-20x3) Screw in Wheel Studs will work on a stock 10 bolt?? I know you have to run open ended lugs because of the length.
Old Sep 23, 2007 | 02:03 PM
EPP's Avatar
EPP
Darren, the 10 bolt probably has press in wheel studs instead of screw in, plus they are going to be 12mm on the 10 bolt. Bob
Old Sep 23, 2007 | 04:11 PM
chicane's Avatar
Sure they will work... but you'll have to drill and tap the flange for the 1/2x20 pitch.
Old Sep 23, 2007 | 05:58 PM
Jake@EPP's Avatar
The stockers are press fit and ARP and moser make a 1/2 press fit as well. The key thing about the screw in wheel studs is the clearance behind the axle flange to make sure you have room for it.
The biggest issue i see is the time you have in converting a stock rear to run a stud that is stronger then it.
Old Sep 24, 2007 | 04:57 PM
SS1875's Avatar
Thanks, I was trying too sell mine from the old 12 bolt and someone with a 10 bolt was asking me about them.
