dana 60/ driveshaft problems! please help
Old Sep 28, 2007 | 10:54 AM
1nverted's Avatar
Default dana 60/ driveshaft problems! please help
i finally swapped my 10 bolt with a dana 60 , had a couple of problems
1. the ride heart after the install was horrible anybody came across this? i still have stock springs and isolators
2. i had to send my driveshaft to be cutdown and rebalanced
3. the u joints on my driveshaft were a hair to wide??? when i had it cut and rebalanced i had the u joints replaced to match the yolk .
now the main problem. after all of this i installed the driveshaft back ,drove it and noticed a squeek almost like a rubbery squeek. i got under it and turned the wheels . sounds like its coming from the u joint in the rear?
is it possible this is just break in noise? it took a little tap to get the u joint in the space. the driveshaft place told me it does not need to be lubricated
anybodys help is much appreciated!
Old Sep 28, 2007 | 10:57 AM
BOTTLEFEDLS1Z's Avatar
The only problem that I had was the DS being to long, so I just took it locally and had a inch cut out of it...
Old Sep 28, 2007 | 02:41 PM
1nverted's Avatar
ttt for some help
Old Sep 28, 2007 | 03:36 PM
98camarossturbo's Avatar
I knew when i bought my s60 that my stock driveshaft would be too long. That's why when i ordered my rear from strange i also ordered a chrome moly driveshaft from them. I wanted to get rid of the stock one anyway do to the fact that it could twist an break.
