1 wheel spinning?
If you have TA the RPO code on the door will tell you what the car came with. Mine had a G80 (limited slip) GU6 (3.42 ratio).
This site lists all GM RPO codes:
http://www.marshu.com/ws6-firebird-c...codes-2000.php
If it has an auburn limited slip the clutches could be worn out causing the 1 wheel peal. If it either really slippery or really sticky you can get this also. When my auburn was going out at the track it would only spin 1.
Brian
BTW, limited-slip and "Posi" are the same thing... ;-)
I don't fully know your circumstances but I've had this problem before and I changed the fluid out and it worked fine.
