Rearend Help
Old Oct 3, 2007 | 09:41 PM
98camaro's Avatar
Default Rearend Help
I have a 434 small block with a TH400 going with a moser 9inch most probably. What gears do you guys recommend? Car is pushing 600hp NA and around 800 with nos. Mostly driven on the street with weekend races. What gears should I go with and spool,locker or posi. I know I ll need to get a different drive shaft, anyone know what size it needs to be. Thanks
Old Oct 4, 2007 | 05:20 AM
EPP's Avatar
EPP
I'd say you probably need 370 gears if you're using a 28" tall tire. Bob
