lock up? rear end problems
Old Oct 6, 2007 | 05:07 AM
sapper_daddy's Avatar
Default lock up? rear end problems
I was riding down the road tonight and I downshifted with some strange results. I have never done this before but for some reason I let out on the clutch a little too quickly, well it made the rear end stutter a bit as I down shifted and immediately after that when I hit the brakes the passenger side would lock up. I rode the emergency brake home....but what are the odds that the axle on that side is loose enough now so that when I even lightly tap the brakes the wheel just stops spinning? This is really odd....anyway I guess I'll have to take the rear tires off and turn the axles to see what is going on. I think it is a strange coincidence that it would be the brakes but does anyone have any opinions? Thanks-Cullen
Old Oct 6, 2007 | 07:43 PM
Okay I didn't get a chance to pull the cover but I did get both the wheels off of the ground. Odd there isn't any grinding or binding. So I need to pull the cover. Anyone have any ideas?
Everything seems normal, just when I tap the brakes the right side completely locks up and goes skidding around...kind of crazy to keep in a straight line! Not driving it now, but any advice would be a great help...thanks!
