10 Bolt Posi HELP!!
Old Oct 13, 2007 | 05:24 AM
Black98Z28's Avatar
Default 10 Bolt Posi HELP!!
I am putting another 10 bolt in my car, however this has a Posi, not the Limited Slip like my previous 10-bolt. Upon inspecting the rearened i noticed this bolt going thru the housing, it was finger tight. Looks like something went thru the bolt, i went to GM and they cannot find what i am needing. Here is a pic of the rearend and the bolt, what goes onto that? Can i run the rearend without that part?
Thanks!!
Old Oct 13, 2007 | 06:33 AM
DaddySS's Avatar
No, you need the spacer block. Either call one of the differential vendors or SLP has a two piece that is used when you go with higher gear ratios or from a 2 to 3 series carrier with thick gears.
Old Oct 14, 2007 | 05:19 AM
Black98Z28's Avatar
anyone know how much that part costs, or what the part number is? Can i get it at the dealer?
Old Oct 14, 2007 | 01:58 PM
8a8mfh's Avatar
Thats the block for the Torsen rear thats missing. Really sucks because I have one at home I could give you. I have no one to get it and ship it and I don't know when I'm going back.
The easiest way would be the SLP as said above, it's the same block cut in two so it fits with the thicker ring gear that 4.10's have. That would be a one call hassle free order.
You could try the dealer, you might need a VIN for a 2000 and up because the '98s used Auburn diffs and a pin instead of a block.
Old Oct 14, 2007 | 04:02 PM
Black98Z28's Avatar
the dealership cannot pull up that rearend, they only call for the auburn. I even gave them a vin for the 2001 SS i got this rearend from and no deal, ill be calling SLP monday morning. Thanks I appreciate it!
