Does a new ring/pinion need to be broken in?
Old Oct 21, 2007 | 01:37 PM
omcar's Avatar
Default Does a new ring/pinion need to be broken in?
Just installed an Eaton posi unit and a new 3.73 ring and pinion. Car is used for bracket racing (drive to the drag strip is approx 30 miles each way). Thanks
Old Oct 21, 2007 | 03:16 PM
BriancWS6's Avatar
Yes. Heat cycle them several times, and then put some miles on them as well. After 2-3 heat cycles, I would drive them for at least a few hundred miles under low load. It would be even better to go 350-500.
Old Oct 21, 2007 | 03:29 PM
omcar's Avatar
is 30-50 miles at moderate mph and then a cool down period considered a heat cycle?
Old Oct 21, 2007 | 03:51 PM
BriancWS6's Avatar
Absolutely. In fact, a shorter interval of mileage, like 10-15, would also suffice.
Old Oct 21, 2007 | 04:05 PM
omcar's Avatar
great..thanks
Old Oct 21, 2007 | 06:46 PM
BriancWS6's Avatar
Anytime
Old Oct 22, 2007 | 11:44 AM
TLewis4095's Avatar
Absolutely! We go 500 miles, and we also break in on regular Dino lube & replace w/full synthetic after that. If you use Syn from the beginning we see high spots in the wear patterns & shorter gear life.
