convertor lockup switch?
Old Jun 11, 2003 | 07:52 PM
Mr.RamAir's Avatar
Default convertor lockup switch?
need directions for making myself a lockup switch for my convertor.
Old Jun 11, 2003 | 08:43 PM
gator's 99TA's Avatar
Default Re: convertor lockup switch?
what you want to do is look to the purple and white wire from the pcm (it is split up into red and blue sides and i BELIEVE, have to check, it is in the red side of the pcm) and just track that back into driver's area where you can control it. from there you want a simple radio shack switch that will allow the wire to ground = convertor locking up. all it is grounding the wire when you need to. real easy and cheap.
Old Jun 13, 2003 | 11:52 AM
Nick's WS6's Avatar
I havent done this but i beleve you can connect the top left and top right pins on the diagnostic port under the dash and that will lock up the converter.
Old Jun 13, 2003 | 02:26 PM
Mr.RamAir's Avatar
someone has to know how to do it?
Old Jun 13, 2003 | 03:28 PM
Roadrunner 45's Avatar
I'd like to know too.
Old Jun 14, 2003 | 09:25 PM
topfig1's Avatar
I did a search a while back on LS1.com and the directions said it was the number 42 pin and that it was tan with a black stripe. You might want to do the same before splicing into PCM wires.
topfig
MGySgt USMC
