How many are running a spool on the streets
Old Oct 29, 2007 | 12:59 PM
blitzed96's Avatar
Default How many are running a spool on the streets
In the market for a 9" now and just wandering how many of you like running the spool on the road. Also I see you can get a mini spool for the stock rear. What is the difference between a full and a mini spool.
Old Oct 29, 2007 | 03:23 PM
Camaro396's Avatar
im putting a 4.10 and mini spool in my car in about a week, just for the simple fact that i hardly drive it, and its cheap, im not about to buy a good posi unit for a 10 bolt. a mini spool goes inside your existing carrier, replacing everything else in it, where as a full spool completely replaces the carrier.
Old Oct 29, 2007 | 03:28 PM
MrDude_1's Avatar
lots of guys run full spools on the road... it doesnt turn well in parking lots, and it can be a handful in the rain, but on a normal dry day driving around, its fine.
on the street, you will want a full spool. a mini spool is for dirt track cars....
the diff between the two is this:
with a full spool, the diff is just one big piece of metal.. the ring gear bolts to it, and the axles slip into the spools splines.
with a mini spool, your ring gear is bolted to your old open diff, with the spider gears and such replaced with the a small chunk of metal. that small piece is the minispool.
now while people have run them on the streets, they also have broken them.. minispools were intended as cheap ways to lock the rear for dirtrack cars.. they have problems with the stress put on them with sticky street tires on asphalt doing parkinglot turns... they're just a bit on the small side for that..
since you dont have a diff to swap to a minispool already, just get a full spool.
Old Oct 29, 2007 | 03:46 PM
blitzed96's Avatar
I'm not to worried about rain and parking lots. I just go for cruises and am hoping to see more track time in the future. I want to build it strong the first time.
Old Oct 29, 2007 | 04:16 PM
blk99camaro's Avatar
I put in a Spooled 9 a little over a month ago. I only notice it in parking lots or the driveway. As for rain I could not tell you. I really like it though, plus I went ahead and got the 35 spline axels and billet yoke, and support. I got mine with Strange's Pro Nodular Iron center with billet bearing caps. The center has a damn data plate with a serial number and all, its overkill for my bolt on car for sure but I dont think Ill have to mess with it antime soon. Mine is nice and quiet too. I got the whole setup from Scott at Driveline Solutions. It was shipped quick and everything I asked for was there. I would recommend him as well as the spooled 9.
Jon
Old Oct 29, 2007 | 04:20 PM
Camaro396's Avatar
i wouldnt waste time beefing up the 10 bolt it will still break even with axles eventually if you make enough power. im only putting a spool in mine right now because i cant afford a 9 inch yet, no way in hell im putting any more money into it though.
Old Oct 29, 2007 | 04:49 PM
bad2000z's Avatar
I didn't think anybody made a mini-spool for 28 spline axles I researched this before, and the only mini-spools I found were for 26 spline axles (g-body cars/S-10's). I was also told they were not strong enough to take much abuse.
Old Oct 29, 2007 | 05:07 PM
Camaro396's Avatar
hmm im pretty sure i found a 28 spline mini spool for our cars before back when i was pricing stuff out. ill have to look again. i could be wrong.
Old Oct 29, 2007 | 09:37 PM
ndfrsd6's Avatar
spool all the way !!!
Old Oct 29, 2007 | 11:15 PM
jt76's Avatar
i have a spool currently, its a pain in my development because of many tight turns etc, ppl look at me like my rear end is about to blow :-)
Old Oct 31, 2007 | 01:14 AM
EPP's Avatar
EPP
If most of your driving is interstate or rural, such as my driving is, then you well seldom even notice you have a spool. I've driven eighty miles in the rain with a Camaro with a spool and M/T drag radials, I kept it at 55 mph and never had a problem. Bob
Old Nov 3, 2007 | 01:40 PM
stevieturbo's Avatar
Ive had a spool in my car since May.
I am so glad its finally out. Bloody horrible at slow speed, and when parking etc. And if trying to go round corners with any speed at all, the damn car only wants to go straight.
I will NEVER drive a car with a spool again, unless it only goes in a straight line.
But as others say, if you can live with that, once at normal driving speeds, driving sensibly, you would hardly notice its in there.
Old Nov 3, 2007 | 11:51 PM
revtime's Avatar
This is exactly my expierence with a spool. I don't even notice it till I get into town and the tight turns I encounter there. I am not as confident about the rain however, It can be done obviously but for me the pucker factor would be high.
Old Nov 19, 2007 | 01:01 PM
BigKap94z's Avatar
Me too. I don't mind the rain or taking my car though the corners though, however on DR's and rain together is a bad combo with any Limited slip/locker/spool.
