questions on rebuilding 9'' centers
Scott @ DLS
Scott @ DLS
2 yokes... 1 with a u-joint size of 27.2ish mm
1 with a u-joint size of 29ish mm
(from what i could tell from my non-dial caliper)
The 2 cases are different also. The one has a drain hold on the side and has a longer and bigger dia. yoke. The other case has no drain hole.
Thats what i got so far till i get further in bearing size.
