Need some help here folks
Old Nov 5, 2007 | 08:40 AM
Twotonefreak's Avatar
Default Need some help here folks
Alright. I'm getting ready to order some 3.73 and an Auburn posi for my 98 T/A. Guy I bought it from was told there were 3.73's put in when he had the rear replaced, well it sure as hell looks like a salvage yard rear end and it only has 2.73's in it.
How can I tell wether its a 2 or 3 series?
Are these rears a 7.5 ring gear?
Am I correct that these are 28 spline?
TIA for any info.
Old Nov 5, 2007 | 12:41 PM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
The 2 series gears are going to be thicker than the 3 series
Old Nov 5, 2007 | 04:58 PM
I needed to know wether to order the thick gears or just a regular gear set so I can have the install done this weekend.
Old Nov 5, 2007 | 07:21 PM
Z28/2002's Avatar
If it has 2.73s then it is a 2 series carrier and yes it is a 7.5 ring gear
Old Nov 6, 2007 | 09:25 AM
01bad ss's Avatar
You are correct that they are 28 spline axles...
