pt4400 + shot at 80?
Old Jan 5, 2003 | 08:51 AM
megathumpzilla's Avatar
Default pt4400 + shot at 80?
Juice from launch would be useless, but would a shot at higher rpm/gear be suicide as well? I know this tc is not for nitrous, but is that just because of the extreme launch or is it an internal thing?
Old Jan 5, 2003 | 09:54 AM
WILWAXU's Avatar
Default Re: pt4400 + shot at 80?
If it hooked.. the N20 would be more beneficial at launch. Problem using N20 with that converter is the amount of RPM's you have to pull.
Have a friend that ran 10.4's with a TP-4400 in a H/C car... but he was all over the 7000 rpm rev limter.
Old Jan 6, 2003 | 12:25 AM
Loco's Avatar
You will definitely feel it from a launch but you will be lucky to get .2 sec from it. You will probably smack your rev limiter pretty hard if you do decide to spray it.
Old Jan 7, 2003 | 05:06 PM
B18B1LS1's Avatar
I spray 150 shot off the line with my PT4400.
I went from 12.3 down to 10.9. While the converter isn't ideal for nitrous it does work pretty well. My RPM's never drop below 6000 and I shift at 6300 but it seems to work for me. I say go for it.
Jeffrey
