T/A girdle, Moser axels, good for...?
Old Jan 7, 2003 | 09:31 AM
Rasp King's Avatar
Default T/A girdle, Moser axels, good for...?
I'm wondering if a T/A girdle with moser axels will be able to handle a set of Nitto drag radials with a stock clutch.
Also, will that rear end setup be able to handle a spec stage 3 clutch?
The car will have around 375rwhp and 355tq by the time I put that stuff in. I just want the 10 bolt to last as long as possible. I don't think I will be doing majorly hard launches.
Old Jan 7, 2003 | 11:56 AM
ROB'S SS's Avatar
Default Re: T/A girdle, Moser axels, good for...?
it will make it a little stronger, but all that stuff has broken in the past. a guy in my club did that with the eaton posi and has gone through 2 posi's, one axle, and a bunch of gears all on the stock clutch and et streets.(internally)stock motor as well
Old Jan 8, 2003 | 11:06 AM
Rasp King's Avatar
et streets hold a lot better than nittos. i'm hoping if i don't heat up the nittos so much they can spin just enough to save the rear.
