gear question
Old Nov 18, 2007 | 06:40 PM
wildn347's Avatar
Default gear question
just got a 98 ta with 2.73 gears and says it has 2 series carrier what is different from that and the 3 series carrier?? because i am looking to get 3.73s
Old Nov 19, 2007 | 02:39 AM
camaroguy26's Avatar
not sure the correct wording, but basically the ring gear on the 2 series carrier is thicker then the 3 series carrier, it doesn't affect the strength, but the 2 series just sits farther away from the pinion. So since 3 series gears are thinner they will not work in a 2 series carrier. Even though I heard they make spacers to even it out, I believe it's 1/4" difference, but I also heard the spacers make it extremely weak. I believe someone makes 2 series 3.73 gears, but you should just get a 3 series carrier somewhere. a really good option is find someone who swapped out their 10 bolt for a 9" or 12 bolt and use their rearend. Sometimes the guys already upgrade the 10 bolt beforehand and it will be cheaper and less work for ya, just make sure the new rearend doesn't whine and is set up right with the gears you want.
Old Nov 19, 2007 | 02:45 AM
wildn347's Avatar
yea i already found 2 series carrier gears for it i was just trying to see what the difference is
