What gear install kit do I need?
Basic Kit: Includes pinion shims, crush sleeve, pinion seal & cover gasket
Complete Kit: Includes pinion shims, carrier shims, crush sleeve, pinion seal, pinion nut, ring gear bolts, cover gasket, and pinion & carrier bearings
Deluxe Kit: Includes pinion shims, carrier shims, crush sleeve, pinion seal, pinion nut, ring gear bolts, cover gasket, pinion & carrier bearings, PLUS wheel bearings and seals. (All of the small parts and pieces necessary to RESTORE an axle to like new condition!)
i was told that with my low miles, i will not need the deluxe kit. so i am deciding between the basic and complete. i was advised to get the complete kit by the tech who will be doing the install. he also advised me to get a solid pinion spacer to use instead of the crush sleeve for more durability and strength. id like some of the gear/rear end gurus in here to advise me on this: which kit will be better and do i need the solid pinion spacer?
