Posi Additive?
Old Jun 24, 2003 | 09:20 PM
Danny2tek's Avatar
Default Posi Additive?
I have A4 and it says when doing a gear oil change to add posi additive if required how do I know if I need it? just do a burn out and see the skids?
Old Jun 24, 2003 | 10:15 PM
trackbird's Avatar
Default Re: Posi Additive?
If you have a TOrsen diff, it is not required (but sometimes used to quiet a "rusty screw" sound in a few vehicles per torsens FAQ's on their website). If you have an auburn diff, auburn says it will not affect the diff if you don't run it, it just may make noise. So, worst case, don't add it and if the rear is noisy, just add it to quiet it down. Or, many synthetic lubes are "Posi Compatible" and don't need extra additive....so there is not really a wrong answer here, you won't hurt anything either way.
Old Jun 25, 2003 | 01:54 AM
Danny2tek's Avatar
o.k another question how do I know if I have an auburn?
Old Jun 25, 2003 | 06:45 AM
Mike K.'s Avatar
I just added it regardless, its cheap and may keep things quieter.
Old Jun 25, 2003 | 07:16 AM
trackbird's Avatar
If it is a torsen, lift the rear axle, put the car in gear and spin a tire, a torsen will spin the opposite wheel backwards...an auburn will not turn at all (if in gear). Or just buy gear lube with additive in it....
