axles different from 93-02?
thanks in advance...
the axles are the same length each side. the only difference will be 3 or 4 channel abs. a 3 channel axle will not work with a 4 channel rearend.... there is no reluctor wheel on a 3 channel axle. i'm not sure of the 3 channel axles have been machined for the reluctor, but if so, the you could just swap the reluctor wheel over from your existing axle.
4 channel axles are in 98-02 tcs equipped cars. you should be able to locate a good used one in the sales section. v6 and v8 cars are the same rearends.
Jeff
