master setting
Old Jan 28, 2003 | 02:31 PM
phat-ss's Avatar
Default master setting
I finally got great clutch pressure by using the minivac system to bleed the air out of my new hydraulics mcleod master and upgraded 02 slave, the problem now is if been palying with where to set the rod length on the master because i cant get car in gear while runnung, it shifts fine when not started but when its started its like the gears are locked out anyone have any idea/suggestions?
Old Jan 29, 2003 | 07:19 AM
99ZEOD's Avatar
Default Re: master setting
It sounds like you need to lengthen it. Now you might be running into the clutch not engaging until it's right at the top. That the problem I had with the Mcleod. Personally I think the Mcleod is best used as a paper weight.
