Transmission Problem Question
I need your help!! What should I do to fix it?!
The tranny is toast!! <img border="0" alt="[bang head]" title="" src="graemlins/gr_banghead.gif" /> The needs a total rebuild not an overhaul. This tranny should have a cable not a metal rod like 70’s model truck with a C-6. This cable on any overdrive is not just a kick down but it also controls line pressure to the tranny clutches. If the cable is not adjusted right or missing then the tranny will burn the clutches.
Kevin Steele
So I am toast. Do I have to change the transmission completely or can it be fixed? Do you know what type of transmission this is so I can get a replacement? Since my truck has a metal rod instead of a cable, can it be replaced with a cable type?
Since it said metric overdrive on the pan then it is probably an AOD. An AOD tranny (all of them) should have a cable, not metal rods. The tranny can be rebuilt at any tranny shop. If you do have a metal rod, you should be able to replace it with a cable. You should not have to get a different tranny to make the swap.
Kevin Steele
