RAM 980
Old Feb 2, 2003 | 06:21 AM
distortion_69's Avatar
Default RAM 980
I'm ordering a ram clutch for my car due to a few recommendations in previous posts. I am ordering the 402 PP from Summit. However, I was told that I should get the organic 980 disc as it was designed for a stock resurfaced/replaced flywheel. I did not see this on Summits page, and only saw this disc offered in a kit from futral motorsports. Can I buy this clutch seperate from the whole VDS system on futralmotorsports. If so, where at? A member of the board is working on my ls6 master cylinder for me. I will also be performing the drill mod. Any experience with the 402/980 setup as far as chatter goes, or pedal pressure? I would think that being designed for the stock flywheel it must not be that extreme and would probably be very daily drivable in both areas. I'm sorta in a hurry to get my baby back on the road.. So any help A.S.A.P. would be appreciated, because I'd like to order it monday! <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Thanks again!
-Josh
Old Feb 2, 2003 | 08:35 AM
NB99Z's Avatar
Default Re: RAM 980
Summit does not stock the 980 disc. If you type in RAM-980 in the part # box it will list it with price as being on B/O. I would call Futal or Rapid and see if they stock the 980.
I have the 402/980 setup and I'm very happy with it. It does chatter at times if you don't rev the engine a little on take off. Pedal pressure is a lot more than stock.
Old Feb 2, 2003 | 10:19 AM
Candy's Avatar
Default Re: RAM 980
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by distortion_69:
and only saw this disc offered in a kit from futral motorsports. Can I buy this clutch seperate from the whole VDS system on futralmotorsports. </font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">We sell the 980 disc separate so give us a call first thing in the morning and we will get you hooked up. The 980 will have very little chatter very similar to stock feel.
Thanks
Old Feb 5, 2003 | 09:49 PM
Default Re: RAM 980
I received my clutch incredibly quick!!
Thanks futral!
The disc has a sticker in the middle that says the clutch warranty is voided if you don't use the ram flywheel. If had known that it would cause a problem I would have ordered the 900 sintered, or 6130. Any comments? Is this something I should be worried about? Or should I just go ahead and re-surface my stock flywheel and run with it.
-Josh
Old Feb 6, 2003 | 10:48 AM
Viper's Avatar
Default Re: RAM 980
I used stock flywheel with 980 just fine, ovewr 4K miles on it now.
