Alignment trouble!!...help
Old Jul 6, 2003 | 02:26 PM
jpz28's Avatar
Default Alignment trouble!!...help
Okay now...I got me a new rearend and we installed it right and everything...works good no trouble...now whenever I went to get it aligned for some reason they can't get it to align....!!....They use the new method where they use laser beams etc. and it doesn't quite get it....Also I noticed that my driver side wheels both front and rear are slightly further in than the other side...in other words the passenger side wheels stick out a little bit more than the driver side....what gives?? T've been thinking of taking it to some other alignment shop where they claim to fix anything if its not aligned due to some other mishalf..........Need help!!
Old Jul 6, 2003 | 02:35 PM
FrankSS's Avatar
Default Re: Alignment trouble!!...help
your front end shouldnt be over any more on either side. if you do, you have major serious problems. if you have an adjustable panhard bar, then thats how you adjust your rear, just grab a tape measurer and go from side to side...
Old Jul 6, 2003 | 06:22 PM
jpz28's Avatar
How serious could they be?
