Another shift kit question TCI guys
Well I started installing the shift kit and got the the part where you replace the 1-2 accumulator spring, and you remove the 3-4 accumulator spring. Well the 3-4 spring was already removed and the piston was installed upside down. Did some trannys come this way from the factory, or did this tranny already have a shift kit installed in it? And if it had a shift kit installed already what problems if any am I going to run into? I completed the install of the TCI kit as per the instructions.
Kevin Steele
