Which material?
Old Feb 4, 2003 | 08:53 PM
blkonblk00ss's Avatar
Default Which material?
Which material should I get my spec clutch with Carbon or Ceramic it is driven daily and raced on weekends, Also do I have to get a new flywheel or can I have mine surfaced a little bit car just has 21,000 miles in it . Thanks
Old Feb 5, 2003 | 06:27 AM
Default Re: Which material?
ttt
Old Feb 5, 2003 | 05:48 PM
OneQuickSS's Avatar
It depends on what you want to spend. If you have the extra money and you want the most out of the car, I would go with an aluminum flywheel. I went with the carbon material because its great for the street and the strip. Not only that, it lasts a bit longer than the ceramic and holds up a bit better than the kevlar. It all depends on what the car is used for. I didnt have the money at the time for a new flywheel, so I just had mine resurfaced. I would of had the money, but I upgraded to a newer slave, and got the McLeod adjustable clutch master.
