need rear end help PLEASE!
Actually it is common for the axle bearings and the axle shafts to wear throught the hard facing of the axle surface. I would not just change one thing at a time though to try and find a problem. Run a pattern on the gear while you have the cover off, is the pinion seal leaking. Exactly what kind of noise? Constant or more of wwhirling noise. Does it change on and off the accelerator? Let me know or give me a call, I would be happy to help you diagnose it correctly and save you some time and money.
Jeff
Before I did that I took the carrier out and checked all those bearings. Left the pinion alone, it spun free, was not loose and makes no noise.
If you have a bad axle don't try an axle repair bearing, they don't physically fit with a torsen differential, actually if you have a '98 you should have an Auburn and a repair bearing should work.
