Ford 9" posi problems
When I boguht the chunk, it had a new set of gears and a rebuilt ford trac-lok posi. I checked the mesh pattern and everything looked good. I put the chunk in with the small bottle of ford friction modifier and posi gear oil in the axel. I went through a brake in procedure of about 5-10 miles driving and let it cool, and did that a couple times. Right now everything feels fine and it makes no noises at all.
So the problem is the posi. At first when I would turn around in the driveway(stone) you could see the inside tire ripping up the gorund. I will admit that after a couple houndred miles of easy driving I have beat on it, couple burnouts, some dounughts
So right now it seems as though the differential is completly open. Under full throttle shifting from 1st-2nd, the passenger side tires just spins like mad. On every turn, giving it alittle gas will result in the inside tire only spinning.
So, It would seem I have smoked the posi. I am going to change the gear oil anyways, so sHould I take it apart and try to rebuild it? Should I put one of them eaton E-Z lockers in it, or a true locker?
Any input or advise would be great.
thanks, Matt
