Burnouts to the right??
Old Jul 10, 2003 | 04:00 PM
LSett's Avatar
Default Burnouts to the right??
It must be something wrong with my rear end, because when i am doing a burnout to the right only one wheel will spin Turning to the left is no problem and straight? I hope someone has an answer
Old Jul 10, 2003 | 05:46 PM
megathumpzillaX's Avatar
Default Re: Burnouts to the right??
posi- it's supposed to do that
Old Jul 15, 2003 | 10:09 PM
JIM F's Avatar
when you are spinning on a right hand turn, and one is spinnin, jerk your steering wheel from right to left quickly to get the car rocking a bit. This should break the other free. It works for me atleast
Old Jul 16, 2003 | 07:28 AM
trackbird's Avatar
THe natural torque of the driveshaft lifts the right rear wheel (non posi cars spin that one only, in most cases). Turning left adds some weight back to the "light" wheel and "evens out" the grip. When turning right, you add grip to the left tire and make the lack of grip on the right side worse. A Torsen differential will transfer power to the wheel with grip and that is what is happening. Then turning left, you simply don't have enough power to spin both wheels. This is the root of your problem.
I suggest a blower....
Kevin
