SLP Driveshaft loop
Old Feb 12, 2003 | 12:54 AM
Humanoid's Avatar
Default SLP Driveshaft loop
Just installed my SLP driveshaft loop. It went in really quickly with no problems.
I know alot of you have the Lakewood made especially for Camaros. I tried it and had big fitment woes. I think I am the exception intsead of the rule as far as that goes.
Anyway just letting you peeps know the SLP fit like a glove.
Hugh
2001 Camaro SS
Old Feb 12, 2003 | 01:43 PM
Humanoid's Avatar
Default Re: SLP Driveshaft loop
OK, I spoke too soon. My y-pipe is now rattleing agains the loop. It has about an 1/8" clear when the car is off but between 2000 and 3000 rpm i guess the pipe vibrates enough to rattle against it.
Can I use some kind of insulation between the two pieces? If so what do you recomend?
I really dont want to remove it again. I am tired of jacking with this and just want it to work. I am gonna try and pry it away from the exhaust first though.
