C5 rears
Will a C5 or C4 rear hold that? The car should weigh somewhere around 2900-3100lbs with me in it.
Also How are these about hooking up?
Oh, it will also be a M6.. Thanks in advance..
<small>[ February 12, 2003, 11:43 AM: Message edited by: LIL SS ]</small>
1) Rear end
2) Some of the front suspension
3) Complete LS6 motor
4) Trans
5) PCM
I'm sure I can find other things I want out of it. Seats and misc items. I'm sure there are going to be a lot of things I don't need though.
What rear is actually a better rear? Things like lower center of gravity, stronger, more adaptable.
As for which is better, I would say that is a tossup. From a weight dist. standpoint, the C5 would be superior as it moves a pretty substantial amount of weight rearward. Packaging (adaptability) on the other hand would be alot easier with the standard Dana 44. You would pretty much need to build the car around the torque tube and transaxle. As for strength either should be fine.
