Brand New 9 Inch Problems
Have you looked to make sure the reluctor rings and sensors all look to be in order at the axle ends?..
We have experienced these same problems after a car has been on our dyno, and it that is the cause you're right, it should go away.
I agree, check everything out at the housing ends if the light continues to stay on. If you continue to have a problem, give the vendor that you bought the rear from a call and see what they can do to help you out. Bob
