PAGING HONDA TRANS FLUID USERS...
Old Feb 12, 2003 | 11:50 AM
Mean Machine's Avatar
Default PAGING HONDA TRANS FLUID USERS...
i've heard that of all things, honda transmission fluid is best to use in our M6's. my question is, do you use the automatic or manual trans blend? thanks.
Old Feb 12, 2003 | 03:27 PM
ScottyG's Avatar
Default Re: PAGING HONDA TRANS FLUID USERS...
Auto trans fluid. The parts guy said there is only one type of ATF.
It didn't seem to make a big difference in mine, but lots of quick-shifting dudes use it.....
Old Feb 12, 2003 | 11:44 PM
thanks for the reply. at the dealership, i saw that they had both auto and manual trans fluid. i'm unsure about the difference between the two. anybody else use this stuff?
Old Feb 13, 2003 | 07:46 AM
TTT
Old Feb 13, 2003 | 11:03 AM
AZ28driver's Avatar
ATF fluid is a thinner weight than manual fluid. If you go on Redlines website a lot of their rear gear oil also list as a manual transfluid. I also think the ATF fluid is a lot cleaner (higher detergent content) than the manual fluid.
