9" questions????
Old Feb 13, 2003 | 09:14 PM
Z06PSI's Avatar
Default 9" questions????
Will a Ford 9" made for a 93-97 LT1 Camaro work in the 98-02's??? Anybody please to let me know.. Have a line on a 9" that I need.
Old Feb 13, 2003 | 09:21 PM
mighty mex's Avatar
Default Re: 9" questions????
just put the backing plates behind the axles so that way you can still use your abs. if you dont care about abs then ya it will work. nothing changed on the rear end, other than the 4 channel abs system.
Old Feb 14, 2003 | 07:30 AM
GeorgeC's Avatar
Ditto... The only real difference is the brake backing plates. If you aren't concerned with ABS, you shouldn't have a problem...
Old Feb 15, 2003 | 06:56 AM
Z06PSI's Avatar
Thanks guys.... <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
