how does my pattern look
Old Mar 5, 2008 | 05:28 PM
slagger's Avatar
Question how does my pattern look
CD 2.304 I have 3.3055
BL .010 - .008 I have BL is @ .008
what you guys think? sorry about the qaulity of pic.
thanks
Attached Thumbnails how does my pattern look-030508_10231.jpg   how does my pattern look-030508_10351.jpg
Old Mar 5, 2008 | 05:32 PM
wrd1972's Avatar
Take some better pics. Try closeup mode and maybe some flash. Hard to tell.
Old Mar 5, 2008 | 05:36 PM
mrhzk35404's Avatar
But it does look off from those pics
Old Mar 5, 2008 | 07:51 PM
slagger's Avatar
Default pict
I'll have to redo it and send some better pictures tomarrow i'm at work now but heres another.
I did have it at .0065 BL and my CD was a couple thousands off but the drive side was to close to the toe so I moved the pinion away from the center .002 and my BL is at .008 and the drive pattern is moving away from the toe.
the shim I have now is what was on there from stock.
2.73 gears
I'm going with 3.42
Old Mar 6, 2008 | 01:02 PM
slagger's Avatar
Exclamation New better pictures
Ok guys I reinstalled it to get my pattern here it is.
CD spec are 2.304 I have it looks close to 2.308
BL specs are .008 - .010 I have .008
good / bad ?
Attached Thumbnails how does my pattern look-dsc04717.jpg   how does my pattern look-dsc04726.jpg   how does my pattern look-dsc04724.jpg   how does my pattern look-dsc04730.jpg
Old Mar 6, 2008 | 07:07 PM
jakesz28's Avatar
I think you need a thinner shim.
Old Mar 6, 2008 | 07:29 PM
slagger's Avatar
won't that move the drive pattern closer to the heel,
and the coast to the toe.
I thought you wanted to keep the drive tores the toe and the coast tores the center.
thanks
