Bracket Help!
Old Mar 9, 2008 | 01:45 PM
proelky's Avatar
Angry Bracket Help!
I need a little help! I had a "clunk" in the back of my car and assumed it was a loose torque arm. Upon inspection I noticed that the shock brackets that are welded to the rearend are cracked. They look aftermarket/cheap, and would probably be better replacing than fixing. Does anyone know where to pick them up at? I have tubular control arms and the bracket looks to be modified to accept them.
Old Mar 9, 2008 | 08:39 PM
keliente's Avatar
Hmm are you talking about lower control arm relocation brackets?
http://www.thunderracing.com/catalog...&vid=3&pcid=94
Old Mar 10, 2008 | 03:21 AM
proelky's Avatar
Thumbs up
That's the one's! However the one's I have actually have a collar that bolt around the axle shafts. I have boxed control arms and tubular lca's and the brackets just fell apart. Seems like I'm fixing someone else's abuse. The prior owner did most of the work engine/susp. and sprayed the car w/out a tune. I ended up welding the brackets and my shock mounts. Thanks for your help!
