The best rear end ??
Old Feb 25, 2003 | 03:14 AM
oOoLy's Avatar
Default The best rear end ??
Which one is better ( Moser and Strange ) ?
Which one is better 12 Bolt or 9 Bolt ?
What is the difference between ( Moser and Strange ) and ( 12 Bolt or 9" ) in the price ?
Thanks
Adnan
Old Feb 26, 2003 | 05:27 AM
oOoLy's Avatar
Default Re: The best rear end ??
tttt
Old Feb 26, 2003 | 09:28 AM
1slowCamaro's Avatar
I would like to know this also.
Old Feb 26, 2003 | 10:22 AM
Boo Yeah's Avatar
either no one will respond or this will become a very big argument
Old Feb 26, 2003 | 01:36 PM
If I got a good deal like at least 500 less for the 12 bolt I'd take it. Otherwise I'd get the 9inch. I just read an article on them. I'm still no pro cuz I believe it takes experience to claim that you know what you're talkin about. After reading that article I'd say the 9 inch is stronger unless you get a super built 12 bolt with 35+ spline axles... The 9" also takes about 3% more power to turn. I'm not planning on making more than 520rwhp in the next 5 years so I'm going with a 12 bolt with 33 splines.
Justin
Old Feb 26, 2003 | 03:51 PM
annil8r's Avatar
Well i say if u use equal parts in each i.e. 33 spline axles, spool, and alloy axles they will both take the same amount of abuse. There are people in here that launch at 6000 rpms on a 12 bolt hundreds of times. the 9" takes about 3% more horse power which is 8-10rwhp. also the 12 bolt is cheaper and its still a chevy part.
Old Feb 27, 2003 | 12:45 AM
35th SS's Avatar
for me price difference was only maybe 200-300dollars.got the moser9.reason-just look solid and bulletproof <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" /> .others have their own opinion.
Old Feb 27, 2003 | 09:18 AM
SilverTAWS6's Avatar
12-bolt: Strong, can do 3 channel abs, lighter, quieter
9" : Heavier, more driveline loss, a little noisier, stronger, removable center section, 4 channel abs only
Depends on what you're doing. I went with the 12 bolt b/c I'm getting into autocross (and I didn't want to spend a ton of money on an aluminum 9" center section). 9" are also usually a little noisier.
As for Strange or Moser, it's whichever you want. I've heard complaints from both camps. Moser is a little cheaper and built faster, Strange uses stock sized axle tubes (no adaptation for brake lines/swaybar clamps) while Moser goes with 3" tubes. Both tend to whine unless you have someone else set them up.
Chris
Old Feb 28, 2003 | 03:25 AM
oOoLy's Avatar
I'm planning on making more than 520rwhp with solid roller cam ,so the 12 bolt with 33 splines will be good or not ?
Thanks
Adnan
