do my own gear install?
Being able to read a gear pattern, and understand what changes you need to make to both the pinion and the carrier will really make or break the job. Its not "common sense" sometimes when it comes to making your adjustments.
Tools... You need a dial indicator, and a magnetic base. Ide say thats the only special tool you really need. Expensive...not hardly. Harbor freight...thats where I got mine. Plus you can use that for doing valvetrain work and some other things. I suggest some big brass punches and a brass hammer, also from H.F. A press helps, but isnt 100% needed. A bearing remover can be a help...but I never use one. I never reuse bearings that I pull off, so I just destroy them and take them off. You'll need a beam style torque wrench in IN-LBS. And a bigger torque wrench that can go up to like 250ft-lbs. The in-lbs wrench I got at NAPA. If you dont have a big torque wrench, autozone rents one for free... Thats it as far as tools that the average joe might not have. And its all stuff you can get use out of again.
Be VERY clean and VERY organized. A piece of grit or a burr under or between shims can ruin your day. Spend lots of time reading and understand set up patterns, and get to know what you need to do if something is out of spec. Things will go much smoother.
Bottom line... if you are only going to do one gear change ever...just pay someone else to do it. If you are going to do it several times, or think you might need to help someone else do it, go for it. Its just like anything else. Do some research, and then dig in. Plenty of step by step write ups online that will help you do the actual work. I work on a lot of jeeps...so I learned to re-gear to save money. Ive done probably a dozen jeep axles and a few 8.8 mustang axles.
I wont get into a detailed desc. because there are plenty of write ups on here and on the net. Some guys will tell you its easier than that...some will tell you its harder... Its what you feel comfortable digging into.
J.
Somewhere on here there was a thread about DIY gear changes, and I think I posted a few links for reference... ill see if I can find it and link it up. I just remembered it.
J.
EDIT: Found the thread I was thinking of. There isnt a ton of stuff...but here it is anyway. There are a couple links in there.
https://ls1tech.com/forums/showthrea...ighlight=yukon
