10-bolt + nitrous from a roll, safe??
Old Mar 2, 2003 | 07:14 AM
Gregg 00SS's Avatar
Default 10-bolt + nitrous from a roll, safe??
I've been against getting nitrous due to need of getting a new rear, which I can't really afford right now. Just rode in my buddies A4 Z28 with nitrous and now I'm more interested. I know from a dead stop, I'll blow the rear if I spray, so that's not even an option. But can a 10-bolt take it from a roll? I'm guessing I probably wouldn't spray until 2nd. Probably be between 100-125 shot. Is this borderline to 10-bolt survival, or would I be fairly safe doing this?? Also, I have pretty much all bolt ons to include a T1 cam.
Old Mar 2, 2003 | 03:27 PM
99ZEOD's Avatar
Default Re: 10-bolt + nitrous from a roll, safe??
From a roll you should be fine. A friend of mine sprayed his TA all the time from a roll and it held up. Now if you add some stickies into the equation you might be asking for trouble down the road.
Old Mar 4, 2003 | 01:29 PM
TreeGreenZ's Avatar
I think it depends on what kind of tires you are going to be running, if you are running street tires, it would take a lot to blow out the rear end. Even nittos will take a little bit. It all depends on how hard you are. I am gonna find out real soon how long my stock rear end will last. Cause I am probably going to be around 420 rwhp, after next weekend....
Old Mar 4, 2003 | 07:01 PM
TrackBurger's Avatar
One of my good friends has an automatic 01 SS with the stock 10 bolt...He has a 3600 stall, 100 shot, and drag radials running 11.8's and no problems. He always sprays from a roll though in 2nd and up.
Old Mar 12, 2003 | 05:31 PM
Gold Phoenix's Avatar
I been racing on BFG DR with other mods. Read my Sig
Old Mar 12, 2003 | 05:47 PM
T/A Medic's Avatar
10.735 @ 128 w/ 150 Shot out of the hole on ET Streets and race preped track... 1.53 60ft
3.73 10bolt w/ TA Cover...
4000 stall, 224 .581 112 cam, LTs, Mufflex, LS6 Intake, and all the other bolt on stuff...
Old Mar 12, 2003 | 08:15 PM
02NBMZ's Avatar
I almost got you beat TA medic
1.59 , 7.12 @100 on 4.10's with a 100 shot
http://texas.clubsi.com/roger/videos/Jeff-DentonN20.mov
