Using a Torque Multiplier on the Pinion Nut
Old Mar 27, 2008 | 11:16 PM
Gary Z's Avatar
Default Using a Torque Multiplier on the Pinion Nut
I thought some of you might like to see the setup I use to remove and install the pinion nut. The central tool is a four-to-one torque multiplier. I also use the torque multiplier on the crank-pulley bolt. New, a torque multiplier is not cheap but it makes these jobs easy.
Attached Thumbnails Using a Torque Multiplier on the Pinion Nut-torquing-pinion-nut.jpg
