Whine Is Cured!
OK so I am putting Motive 4.10's in my stock 10-bolt rear in my 98 TA as we speak. This is a true 4.10 with a 10 tooth pinion. I replaced all the bearings and seals. Right now I've got a good contact pattern and about .003 of backlash. It's turns smooth as glass, but I know it's supposed to be minimum of .005 backlash. My question is: What will happen if I run it at .003 instead of loosening it up to .005? What is the best recommended setting for QUIETEST operation? I dont care about strength, I want them QUIET. Thanks for your help!
