Gear swap
Old Apr 1, 2008 | 12:29 AM
d's camaro's Avatar
Default Gear swap
I was just wondering for the guys who switched from 2.73 to 3.73's , what size pinion shim did you use ? A buddy of mine who is installing them for me wanted to know so he could use a base to start with.
Thanks !!!
Old Apr 1, 2008 | 01:04 PM
GuitsBoy's Avatar
Start with stock, in most cases its .035 if I recall. If the pinion depth is off, adjust as necessary.
Old Apr 1, 2008 | 01:55 PM
Jawsgear's Avatar
What brand of gears are you using?
Jeff
Old Apr 2, 2008 | 01:19 AM
d's camaro's Avatar
I forgot to mention that I'm using richmond gears
Old Apr 2, 2008 | 01:23 PM
Jawsgear's Avatar
Start around a .028". Make sure tocheck the pattern as the gears can vary on depth shim. This would be my starting point though.
Jeff
