Auburn carrier differences
The 13.42 on the gear has nothing to do with the carrier on which it's mounted.The 13.42 is probably the gear ratio(42 divided by 13=3.23).3.23 would indicate it's a 3 series Auburn.
To tell if it's worn look at the plates that the springs are in between. There is a tab on each plate that bends toward the center. The more wear on the side gears/case the more gap between these tabs. A good one will have under a .125 gap.
