Should I risk the 10bolt?
Old Apr 16, 2008 | 06:01 PM
SVT THIS's Avatar
Default Should I risk the 10bolt?
Ok here's the deal. I just got my car finally running after nearly a year. Here are the specs real quick.
LS2 402, outta box GM L92s, L76, 90mm TB, big *** cam. The transmission is a fully built full manual 4L80e. The rear end is a GM 10-bolt that is brand new and was replaced about 10-15k miles ago. I realize I should have just bought a 12 bolt but I had not intended on taking the modification of the car this far.
So, should I risk taking it the track this weekend with a set of slicks and running it two or three times to see what it will run? Or would that most likely be pushing my luck? I know that there is no sure way of knowing when it will break but I would like to know what my odds are.
Old Apr 16, 2008 | 06:08 PM
01ssreda4's Avatar
i wouldn't, the ten bolt is worth more unbroken..........
Old Apr 16, 2008 | 07:41 PM
MIKE02WS6's Avatar
My buddy shaved several teeth on his gear set. Stock 346cid, some bolt-ons, drag radials, and a 2K rpm launch. Guys have broken their 10-bolts with Stock power on drag radials. Some guys run 10's on their rear. It might be a good idea to tow it there. Then who cares, launch away
Odds 402+slicks=prolly not too good
Old Apr 17, 2008 | 04:17 AM
EPP's Avatar
EPP
Thumbs up
I agree. Bob
Old Apr 17, 2008 | 04:57 AM
SVT THIS's Avatar
Well ****. That is not what I was hoping for...I pretty much knew the response. I could kick my own *** for putting a GM 10 bolt on the credit card, making it as much as 12 bolt..
I would tow it there, but, I just put some of my transmission on the credit card. That means I can't afford a 12 bolt just yet.
I have some pretty shitty street tires that seemed to hook just a wee bit, I may give those a shot.
What about some almost bald nitto DRs? Et streets? Those are probably outta the question too huh?
Old Apr 17, 2008 | 05:18 AM
EPP's Avatar
EPP
With an automatic you do stand a better chance of keeping the 10 bolt alive. Nitto's may work, as they don't provide a whole lot of bite. Bob
Old Apr 17, 2008 | 08:44 AM
Hennytime's Avatar
mine survived on m/t et streets for a while, not i have the hoosiers so we shall see. i have a spare 10 bolt though haha
