help with my drive shaft
Old Apr 21, 2008 | 04:18 PM
thebart455's Avatar
Default help with my drive shaft
im taking out my drive shaft to put in new universal joints, i took off the rear clips that hold the rear universal joint to the yoke but the shaft wont budge im not really familer with drive trains
Old Apr 21, 2008 | 05:12 PM
keliente's Avatar
It's most likely just rusted in place if you've never removed it before. Lightly take a pry bar to it.
Old Apr 21, 2008 | 06:53 PM
koolaid_kid's Avatar
Or lightly tap it with a BFH to break it loose. The shaft should slide forward into the tail section of the transmission. The caps may slide off the ends of the u-joint, but that won't matter since you are replacing them.
