9" Help!
Old Apr 23, 2008 | 08:17 PM
neeshSS's Avatar
Default 9" Help!
I'm planning on getting a 9" inch really soon. Probably a spool, 4.11's, 35 spline, backbrace, drain and fill plugs, 3 channel, new driveshaft. Anyways..I'm running Texas-speed true duals right now, but i want to run a tq arm with a driveshaft loop, that isn't in the stock location. Which ones fit, or am I going to have to change my exhuast up. Anyone help me out??
Old Apr 24, 2008 | 08:04 AM
mcflyz28's Avatar
I did, x-pipe and mufflers sitting on the floor in my office, they were dumped and with the turndown cut off they still hit the center section, no way I could get the trak pak torque arm in with the exhaust on the car so I sawzalled it off.
Old Apr 24, 2008 | 10:27 AM
neeshSS's Avatar
so you're saying it's a no-go with the duals. I figured that much. What about with the 9" and tq arm from Midwest Chassis & Performance?
Old Apr 24, 2008 | 11:29 AM
mcflyz28's Avatar
All my stuff was welded up I'm sure that didn't help.
Old Apr 24, 2008 | 05:34 PM
Jawsgear's Avatar
I believe the new M9 is designed to work with the duals. It is a prices piece and made primarily for the guy/gal that does a lot of racing though.
Jeff
