help somthing popping!
Old Apr 24, 2008 | 01:06 PM
thebart455's Avatar
Default help somthing popping!
i noticed the other day when i slam the throttle on my car it makes a popping sound (real loud) which i can feel in the car, i changed the universal joints in the drive shaft but it did not help. it drives fine if i dont go wot in 1st or 2nd gear. doesent pop when i turn or anything. im thinking it may be my posi unit going bad
Old Apr 24, 2008 | 04:48 PM
Jawsgear's Avatar
Could be the posi or abroken tooth on the ring and pinion.
Jeff
Old Apr 28, 2008 | 07:10 AM
miller456's Avatar
I'm having the exact same problem and cant figure out what it might be. When you want to launch from a dig as soon as I let the clutch go it pops hard then never does it again. Then if im goin from a roll and punch it hard in 1st and when i go to 2nd it will pop once and every other gear and normal driving its fine I never hear it again. I just put the ms4 in mine and still have stock gearing so I was curious if i could remedy the situation with a gear swap? I'm glad you posted this I would like some more insight as well.
