LT1 ABS and LS1 ABS 3 ch the same?
Old Apr 30, 2008 | 08:18 PM
dansean1's Avatar
Default LT1 ABS and LS1 ABS 3 ch the same?
Assuming both cars, LS1 and LT1 are 3 channel ABS, is there any reason they would not be compatible?
Far out idea, different # of teeth on ring gear reluctor gear for ABS that could cause a problem?
Please chime in if you know something thanks
Old May 1, 2008 | 09:20 AM
dansean1's Avatar
does no one know?
Old May 1, 2008 | 11:34 AM
95GreenZ28's Avatar
They should be the same
Old May 2, 2008 | 12:23 AM
ssvert99's Avatar
LS1Tech Premium Sponsor
they are the same... there was a different reluctor for the 93-97 cars vs. the 98-02's, but the teeth count and the sensor are the same.
Old Jul 5, 2008 | 01:37 PM
Deceptikon's Avatar
Back to the top for relevance to my interests.
Would an aftermarket brake setup off my 2000 ta fit onto one of these diff's?
Old Jul 7, 2008 | 11:26 AM
ssvert99's Avatar
should be no problem... the brake offset and housing flange pattern is the same for both.
Old Jul 7, 2008 | 11:33 AM
Bad Blue WS6's Avatar
LT1 and LS1 reluctor rings are different,,,the LT1 ring is quite bigger, (3/8th of an inch) ,and wont allow the speed senosr to fit if your using LS1 brakes. (your sensor will hit the teeth of the LT1 reluctor ring, not allowing it to go in all the way.) Ask me how i know that one.... thank God i bought my own press...
Old Jul 7, 2008 | 12:03 PM
ssvert99's Avatar
^^^ correct for the axle rings... 3 channel is all the same though.
