Tranny problem???
Old Mar 21, 2003 | 04:59 PM
94z28ls1's Avatar
Default Tranny problem???
I just finished installing a 2002 motor and tranny in my 94 camaro and when I put it under heavy throttle I hit the rev limiter in 2nd gear when it happens my speedometer quits working (my car is an automatic and has ls1 edit installed) has anyone ever heard of this happing and what is causing it. Also it slips from 3rd to 2nd under really light throttle. HELP!!! Computer problem??? <img border="0" alt="[cry]" title="" src="graemlins/gr_cry.gif" />
Old Mar 22, 2003 | 06:03 AM
94z28ls1's Avatar
Default Re: Tranny problem???
My problem is getting worse tonight it started slipping in and out of gear in all gears at all speeds when it slips between gears my speedometer drops way down even though im not losing speed. Any suggestions on what the problem is would save my life right now!!!!!!!!!!!! Please help anything give me a clue <img border="0" alt="[bang head]" title="" src="graemlins/gr_banghead.gif" /> <img border="0" alt="[bang head]" title="" src="graemlins/gr_banghead.gif" /> <img border="0" alt="[cry]" title="" src="graemlins/gr_cry.gif" /> <img border="0" title="" alt="[Frown]" src="gr_sad.gif" />
Old Mar 22, 2003 | 06:05 AM
94z28ls1's Avatar
My cam shaft positioning sensor is out would this be causing it?
Old Mar 22, 2003 | 07:38 AM
99taws6's Avatar
check your Vehicle Speed Sensor... This could be bad causing that..
Old Mar 22, 2003 | 08:04 AM
94z28ls1's Avatar
I'll do that and post if it is bad thanks for the input
Old Mar 22, 2003 | 04:06 PM
94z28ls1's Avatar
Found the problem a bad connection at the pcm thanks for the help
Old Mar 23, 2003 | 12:03 AM
94z28ls1's Avatar
Changed out the VSS but I still have the exact same problem. When I put it on the diagnostic machine it reads all kinds of crazy speeds when the car is in drive. Are there any other explanations of why this might be happening????
