Is Slave broken
Old Mar 23, 2003 | 06:22 AM
SoCal LS1's's Avatar
Default Is Slave broken
Pulled trans to replace clutch due to noise and slipping. Found clutch shot and flywheel, presure plate severely hot spotted. Noticed a ring that came off the inside of slave and was dangling on the input shaft. Does that mean the slave is broken or is it a shim used. Car has stock clutch 99TA I did a search and found nothing related to a ring coming off a 99 slave. Any advise would be appreciated
Old Mar 23, 2003 | 04:17 PM
Default Re: Is Slave broken
ttt
