How to get front spindles off?
I used the cold chisel method and it worked fine. An air chisel might be just as effective if you have access to one and don't go crazy with it.
On the re-install, just take some emmry cloth and clean up the hub and spindle surface. The bearing should slip right into the spindle without having to use the bolts to pull it into the spindle.
Chris
